Vehicle shut off at stop light and will not start
230,000 MILES • V8 • 4WD
MARTIN PEREZ
My vehicle listed above came to a stop and shut off on me. i thought it was the battery because it was getting bad but in replaced it. all lights turn on inside but the dashboard and it won't start.
Jan 16, 2021 at 2:05 AM
When you say it is not starting, does the vehicle even crank and not start or does it not do anything when you turn the key? Here is a guide that we need to run through if it is not doing anything:
If it cranks but does not start then we need to start with this guide:
Also, here is a guide that will help with checking fuel pressure which is the first thing we need if the engine will crank but not start:
Let's start with this and then go from there. Thanks
Jan 17, 2021 at 9:00 AM
