Car shuts off when i give it gas
164,387 MILES • 3.1L • 6 CYL • FWD • AUTOMATIC
DOUGLAS D
The car will run good until go to give it gas.
Jan 9, 2017 at 1:01 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it and scan for codes. See link.
Jan 9, 2017 at 4:24 AM
RENEE L
  • 1,260 POSTS
Hi DOUGLAS D,
If you decide to scan for codes as HMAC300 suggested here is a link that will be of help to you. This link features an informative article with written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com.
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jan 9, 2017 at 7:37 AM
DOUGLAS D
I am getting code 22 TPS signal voltage is low.
Jan 12, 2017 at 7:34 AM
HMAC300
  • 48,601 POSTS
See pictures to test circuit it can be a bad TPS and or a vacuum leak to map sensor. so check that as well.
Jan 12, 2017 at 8:49 AM
DOUGLAS D
I put new TPS and MAP. I checked for vacuum leak.
Jan 12, 2017 at 8:52 AM
HMAC300
  • 48,601 POSTS
well with the pictures I sent you can test if light is still on. also, clean throttle plate on both sides and clean IAC hole may help this.
Jan 12, 2017 at 9:17 AM
DOUGLAS D
I am getting code 42 now electronic spark timing (est) circuit open or shorted direct ignition system (dis) faucet by pass circuit open or shorted to ground during engine run. do not know what that mean
Jan 13, 2017 at 1:44 AM
HMAC300
  • 48,601 POSTS
see pictures on how to diagnose the problem.
Jan 13, 2017 at 4:25 AM
