Car cuts off why I'm driving it
104,000 MILES • 2.4L • FWD • AUTOMATIC
PATRICK GLOVER2
  • 7 POSTS
I was driving and tha car cuts off wouldn't start back but it will turn over like it will start but want is it because it jumped timing are could it be something else
Apr 18, 2017 at 6:54 AM
CARADIODOC
  • 34,415 POSTS
A jumped timing chain is always a possibility, but there are plenty of other suspects. You need to determine if you're missing spark, fuel injector pulses, or more commonly, both. The diagnostic fault codes should be read and recorded. Those may indicate the circuit that needs further diagnosis.
Apr 18, 2017 at 11:57 AM
PATRICK GLOVER2
  • 7 POSTS
Everything is working
Apr 18, 2017 at 1:05 PM
CARADIODOC
  • 34,415 POSTS
Then the engine will start and run. You need fuel, air, compression, spark, and proper timing. One or more of those has to be missing.
Apr 18, 2017 at 1:39 PM
PATRICK GLOVER2
  • 7 POSTS
It turns over like it want to start be don't
Apr 18, 2017 at 2:34 PM
CARADIODOC
  • 34,415 POSTS
As I said, something is missing. You have to figure out which is missing, then we can figure out if it's something we can diagnose together.
Apr 18, 2017 at 3:11 PM
PATRICK GLOVER2
  • 7 POSTS
Ok
Apr 18, 2017 at 7:27 PM
CARADIODOC
  • 34,415 POSTS
Sorry that I neglected to explain the diagnostic fault codes better. There's over 2,000 defects the Engine Computer can detect and set a fault code for. Only about half of them refer to things that could adversely affect emissions, and those are the codes that turn on the Check Engine light. A non-running engine can't pollute excessively, so whatever is causing the no-start likely will not turn on the Check Engine light. To add to the misery, some fault codes take some time to set, and the few seconds a stalled engine takes to coast to a stop may not be long enough.
Regardless, reading and recording the fault codes is always the place to start. They never say to replace a part or that one is bad. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. Mechanics use very expensive scanners to read the fault codes in all of the car's many computers. Simple, inexpensive code readers only read codes in the Engine Computer, which is what you need. The people at many auto parts stores will use one of those readers to read your fault codes for free. A lot of those stores also rent or borrow tools and they are likely to have a code reader you can borrow. All '96 and newer cars have the diagnostic port right under or near the steering column, under the dash.
Apr 18, 2017 at 7:46 PM
PATRICK GLOVER2
  • 7 POSTS
I will try that
Apr 18, 2017 at 10:16 PM
  • 55,770 POSTS
Please let us know what you find so it will help others.
Best, Ken
Apr 22, 2017 at 3:36 AM
PATRICK GLOVER2
  • 7 POSTS
What u think it might be
Apr 22, 2017 at 4:55 AM
PATRICK GLOVER2
  • 7 POSTS
Ken
Apr 22, 2017 at 8:57 AM
  • 55,770 POSTS
You will need to do some tests. here is a guide to get you in the right direction.
https://www.2carpros.com/articles/engine-stalls
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
Apr 22, 2017 at 1:26 PM
