Intermittent issue of shutting off when slowing down and depressing the clutch
350,000 MILES • 1.5L • 4 CYL • MANUAL
PC PAYNE
I just got the timing belt replaced. Car runs very good except now seems to sometimes shut off, especially on the freeway when slowing down due to traffic and clutch is depressed... five speed Manual. Mechanic insists it's not the timing belt repair. Any helpful suggestions???
Mar 16, 2022 at 8:31 AM
  • 110,244 POSTS
The belt itself wouldn't be causing this. However, I need a bit more information. Do you mean when you depress the clutch (engine at idle) it stalls?
The first thing I would check is if there are any engine vacuum leaks. There were a lot of parts taken apart for the replacement of the timing belt. There is a chance something was left disconnected or was damaged.
Take a look through this link. It explains how to check for leaks. Try this and let me know what you find
Also, it would be a good idea to see if there are any diagnostic trouble codes stored. This vehicle has an OBD1 system that doesn't require a scanner to retrieve codes. Follow this link and let me know if there are any codes are found.
https://www.2carpros.com/articles/honda-car-1990-1995-obd1-code-retrieval-procedure-and-definition-table
One other thing. Take a look through this link and let me know if anything helps.
https://www.2carpros.com/articles/stall-at-idle
Let me know what you find.
Mar 16, 2022 at 11:51 AM
