You should have replied to the previous thread so that whoever was atttaneding to you can response when notification is received. Posting a new thread might get missed out due to overhelming questions coming in.
It is possible the mount(s) was/were weak and the replacement of the clutch aggravated or caused them to fail.
The vibration could be due tio the clutch job but you did not mention slipping in your previous post so I am not able to ascertai if it is related unless you are able to provide more information on the symptoms.
The jerking could be due to bad mounts.
The rough ride, if it is what you meat with the jerking, it could be a fault with the ignition system and I would suggest checking the spark plug wires and other ignition parts are correctly and securely installed.
SPONSORED LINKS
Wednesday, October 7th, 2009 AT 12:23 PM
