Car Cuts off at stop signs or Lights
175,000 MILES • FWD • AUTOMATIC
DBLB1965
I drive about 60 miles a day, mostly on the freeway. For the past month or so, at least 2 to 3 times a week, when I start the car up, it will idle low and when i put it in gear, it will shut off. I have to start it in neutral, with one foot on the gas pedal and the other on the brake to raise the RPMs, put it in drive and take off..... then when coming to a stop, put it in neutral and repeat the process... Whats my problem??? Cause it dosent happen all the time.
Aug 26, 2014 at 4:09 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner.
Aug 26, 2014 at 5:08 AM
DBLB1965
thanks, I'll try it
Aug 26, 2014 at 5:44 AM
