The engine cranks but does not start?
2,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
TRUCKWES
  • 37 POSTS
cranks no start. Replace fuel pump. The car has spark, it did not jump timing. Has injector pulse. Cylinder compression 140. What is the problem?
Jun 21, 2025 at 9:49 AM
  • 55,694 POSTS
Will the engine run on starting fluid? This is an easy way to tell if it is fuel pressure, please go over this video to help show you what to do:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Please go over this guide and get back to us.
Jun 22, 2025 at 5:57 AM
TRUCKWES
  • 37 POSTS
The engine will not run on starting fluid Replace the fuel pump. Engine will not run.
Jun 24, 2025 at 9:58 AM
  • 55,694 POSTS
So the engine has fuel, compression and spark but it wont run correct? Lets run the codes to see if any are stored, here is a guide to help. Do you have a security light flashing when the engine is cranking?
Jun 25, 2025 at 4:00 AM
TRUCKWES
  • 37 POSTS
I have fuel, compression and spark. Security light not flashing. No codes present. Could it be the timing?
Jun 26, 2025 at 6:52 AM
  • 55,694 POSTS
Yes, it could be timing, what was the average compression reading? Usually, the compression will be low if the cam timing is off.
Please go over this guide:
Jun 26, 2025 at 9:50 AM
TRUCKWES
  • 37 POSTS
Found VVT sprocket at the end intake and exhaust camshafts bad. I will take the car a Auto Tech. Thank you for the info.
Jun 29, 2025 at 12:50 AM
  • 55,694 POSTS
Hmm, usually the engine will stills tart with the VCT going bad but you never know. Please let me know what happens.
Jun 29, 2025 at 2:55 AM
