The engine cranks but will not turn over?
101,000 MILES • 2.5L • 6 CYL • AUTOMATIC
PURPLEBUTTERFLY613
The car cranks, but isn't turning over. Dashboard lights come on. Battery is about a month old. 1/2 tank of gas.
Sep 2, 2023 at 4:11 AM
  • 110,246 POSTS
When you have a crank no-start condition, it is usually one of two things. Either the ignition spark is lost, or fuel pressure is lost.
Here is what I need you to try. See if it will start if you use starting fluid. If it starts and then stalls, we will know its fuel related. If there is no change, then I need you to check for an ignition spark.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results. Also, pay attention to see if the tachometer is moving at all when cranking the engine.
joe
Sep 2, 2023 at 2:20 PM
PURPLEBUTTERFLY613
Okay thanks! Well try that.
Sep 2, 2023 at 10:53 PM
  • 110,246 POSTS
You are very welcome. If you have a chance, let me know what you find. I'm interested in knowing.
Sep 3, 2023 at 1:45 PM
