Engine cranks but will not start, replaced TIPM and alternator
140,000 MILES • 2WD • AUTOMATIC
DIZ&SHA
Also, after turning key to start and letting go back to run it still cranks. I have to turn the key to the off position for it to stop.
Sep 30, 2018 at 4:41 AM
  • 110,248 POSTS
The first thing we need to determine is if there is spark and fuel to the engine. Here is a link that shows what to check for:
Fuel pump test:
Ignition spark test:
_____________________________________
Here are the fuel pressure directions specific to your vehicle. Both attached pictures correlate with these directions.
CHECKING THE FUEL DELIVERY SYSTEM
Special Tools:
For a complete wiring diagram, refer to the Wiring Information .
1. FUEL PUMP OPERATION
1. Ignition on, engine not running.
2. With the scan tool, actuate the Fuel System test.
NOTE: It may be necessary to use a mechanics stethoscope in the next step.
3. Listen for fuel pump operation at the fuel tank.
Does the Fuel Pump operate?
- Go To 2
- Go To 5 CAUTION: Stop All Actuations.
2. FUEL PRESSURE
WARNING: The fuel system is under a constant pressure (even with the engine off). Before testing or servicing any fuel system hose, fitting, or line, the fuel system pressure must be released. Failure to follow these instructions can result in possible serious or fatal injury.
Perform the following procedure to purge air from the system:
- Open the Fuel System Isolation Valve (1).
- Close the Flow Test Valve (2).
- Ignition on, engine not running.
- With the scan tool, actuate the fuel pump.
- Open the Flow Test Valve (1) for 10 seconds, then close the Valve. CAUTION: Stop All Actuations.
- Turn the ignition off.
- Disconnect, empty and then reconnect the Reservoir Assembly.
1. Turn the ignition on, wait five seconds, turn the ignition off and then wait one minute before proceeding.
2. Read the Fuel Pressure Gauge (3) and record the reading.
Choose a conclusion that best matches your fuel pressure reading.
Below Specification
- Go To 3
Within Specification
- Test Complete.
Above Specification
- Replace the fuel pressure regulator.
- Perform the POWERTRAIN VERIFICATION TEST. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > Powertrain Verification Test.
3. RESTRICTED FUEL SUPPLY LINE
WARNING: The fuel system is under a constant pressure even with the engine off. Before testing or servicing any fuel system hose, fitting or line, the fuel system pressure must be released.
1. Turn the ignition off.
2. Disconnect the Fuel Pressure Decay Tester.
3. Raise the vehicle on a hoist and disconnect the fuel pressure line at the fuel pump module.
4. Install the Fuel Pressure Decay Tester between the fuel supply line and the fuel pump module.
5. Ignition on, engine not running.
6. Using the scan tool, actuate the Fuel System test and observe the fuel pressure gauge.
Is the fuel pressure within specification now?
- Repair/replace fuel supply line as necessary.
- Go To 4
4. CHECKING FUEL INLET STRAINER
WARNING: The fuel system is under a constant pressure (even with the engine off). Before testing or servicing any fuel system hose, fitting or line, the fuel system pressure must be released. Failure to follow these instructions can result in possible serious or fatal injury.
2. Remove the Fuel Pump Module and inspect the Fuel Inlet Strainer. See: Fuel Tank > Removal and Replacement > Fuel Tank - Removal.
Is the Fuel Inlet Strainer plugged?
- Replace the Fuel Pump Inlet Strainer. See: Fuel Tank > Removal and Replacement > Fuel Tank - Removal.
- Replace the Fuel Pump Module. See: Fuel Tank > Removal and Replacement > Fuel Tank - Removal.
5. FUEL PUMP OUTPUT CIRCUIT OPEN
2. Disconnect the Fuel Pump Module harness connector.
3. Ignition on, engine not running.
4. With the scan tool, actuate the Fuel System test.
5. Using a 12-volt test light connected to ground, probe the Fuel Pump Output circuit.
NOTE: The test light should be illuminated and bright. Compare the brightness to that of a direct connection to the battery.
Does the test light illuminate brightly?
- Repair the excessive resistance or open in the Fuel Pump Relay Output circuit.
If the engine is cranking and fails to start, one of the two things I listed are most likely the cause. Check those two things first. Also, if the check engine light was on, I would recommend scanning the computer for trouble codes. Here is a quick video showing it being done. I realize most people don't own a scanner, but often times a parts store will lend or rent one to you.
https://youtu.be/YV3TRZwer8k
Once you determine what is missing, let me know so I can guide you through the repair process.
Take care, and I hope this helps.
Oct 1, 2018 at 11:21 AM
