Car cranks but won't start, no spark.
200,000 MILES • 3.5L • 6 CYL • RWD
VFAVES
Hi, I put a new ignition coil in and also a crankshaft position sensor. Still no voltage to primary coil . I have also replaced fuel pump relay.
Was given code 1444 with stomp test before installing crankshaft position sensor. Now ,after installing crankshaft, i did stomp test again and received code 1233. Any ideas on how to get my car going again?
Mar 4, 2017 at 5:30 AM
KHLOW2008
  • 41,812 POSTS
The primary coil reveives its volage from the ignition switch. Use a fuse jumper to supply power to the ignition coil to test if you are able to start. It could be a faulty ignition switch.
Mar 4, 2017 at 11:54 PM
