I try to start car, will crank but will not start can we fix it please?
Jan 28, 2020 at 10:10 AM
✓Experienced Mechanic
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
