Car cranks but unable to start
2007 HYUNDAI ELANTRA
108,118 MILES
STRICT
Car overheated and so i changed the head gasket i realised water had mix with the oil in the head, timing in place but my car fails to start. Am very worried n need sm help on how to about the situation
Aug 20, 2013 at 1:59 AM
WRENCHTECH
  • 20,761 POSTS
Did you send the heads out to a machine shop to be inspected and pressure tested?
Aug 20, 2013 at 3:03 AM
STRICT
No, dispersed the parts to replace the gasket and resurfaced it with timing in place. Though there is a cranks the car doesn't start.
Aug 21, 2013 at 12:00 AM
WRENCHTECH
  • 20,761 POSTS
That pretty much means you'll be doing the job over. The head needs to be tested and at the very least, planed to true the surface.
Aug 21, 2013 at 2:47 AM
STRICT
Tnx 4 the reply, am on my way 2 the machine shop. I shall keep u updated. Tanx
Aug 21, 2013 at 7:14 AM
STRICT
I realised that the valves are leaking, so i have decided to grind them with a paste b4 i fix the head. Could the valve leakage a the reason why it not starting? Also i mixed the valve covers at the machine shop can that cause any harm? The man @ the machine shop said the head is ok.
Aug 22, 2013 at 3:59 AM
MADMIKE1735
  • 951 POSTS
dual over head cam right? there is a tsb for the timing chain that connects the two cams together.... how did u install that chain??? and your certain your timing belt marks are correct?
Sep 14, 2013 at 10:13 PM
