car cranking but not starting
1998 TOYOTA
168,700 MILES
BIGBOY MUROYIWA
On a toyota vista there is fuel and spark but not starting, throttle body sensor is not clicking. Ignition is on earth is there on throttle position sensor. engine check light showing continuously if you bridge the obd2 connector. all fuses are good its an automatic car. yesterday it was moving but with no power then decided to to change spark plugs. all electrical cables are intact.
May 23, 2013 at 11:10 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first
May 23, 2013 at 11:32 PM
ADMIRE
Engine cranking but not starting
Jun 9, 2016 at 9:18 AM
HMAC300
  • 48,601 POSTS
do what I said in first reply also check pgm and main relays.
Jun 10, 2016 at 4:59 AM
