Car cranking but not starting
BIGBOY MUROYIWA
  • 1998 TOYOTA
  • 168,700 MILES
On a toyota vista there is fuel and spark but not starting, throttle body sensor is not clicking. Ignition is on earth is there on throttle position sensor. Engine check light showing continuously if you bridge the obd2 connector. All fuses are good its an automatic car. Yesterday it was moving but with no power then decided to to change spark plugs. All electrical cables are intact.
Friday, May 24th, 2013 AT 6:10 AM
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure first
Friday, May 24th, 2013 AT 6:32 AM
ADMIRE
Engine cranking but not starting
Thursday, June 9th, 2016 AT 4:18 PM
HMAC300
  • 48,601 POSTS
Do what I said in first reply also check pgm and main relays.
Friday, June 10th, 2016 AT 11:59 AM
