car continues to overheat
190,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
WILLIE ROBY
When you first start the car up in the morning after fifteen minutes it overheats. I have replaced the water pump and the thermostat and it still does the same.
Feb 18, 2018 at 6:26 AM
Good morning.
A bad cooling fan or one not operating will cause overheating.
A clogged radiator will also cause this.
What concerns me is the fact that it has overheated several times. there also could be a damaged head gasket causing the issue.
Feb 18, 2018 at 6:53 PM
