Car continues to overheat
WILLIE ROBY
  • 2005 CHEVROLET IMPALA
  • 3.0L
  • 6 CYL
  • 190,000 MILES
When you first start the car up in the morning after fifteen minutes it overheats. I have replaced the water pump and the thermostat and it still does the same.
Sunday, February 18th, 2018 AT 2:26 PM
  • 52,797 POSTS
Good morning.
A bad cooling fan or one not operating will cause overheating.
A clogged radiator will also cause this.
What concerns me is the fact that it has overheated several times. There also could be a damaged head gasket causing the issue.
Monday, February 19th, 2018 AT 2:53 AM
