car codes
1997 CADILLAC DEVILLE
208,019 MILES
REARDRIVE
  • 93 POSTS
97 cad.deville northstar; code po550 pop up on the onboard computer I can not find this code in the code section what this code mean and how to fix it. I replace the idle control switch last month and code p1654 what this mean, how you go by fixing these problems thank you
May 25, 2013 at 11:56 PM
HMAC300
  • 48,601 POSTS
that is a powersteering switch chec fuse first may be underhood then have apro scan it as that is the only way to tell what is wrong.
May 26, 2013 at 1:25 AM
REARDRIVE
  • 93 POSTS
Is this the answer to code po550, if is the answer now what code p1654 mean,what can I do to fix it
May 26, 2013 at 4:09 AM
HMAC300
  • 48,601 POSTS
dowhat I said in first response for 550 the second one is cruise control has no output, both of these need to have a pro type scan tool hooked up to it to see where the problem is. so take it to a mechanic and have h im scan it to find the problem. Just like I said in first response.
May 26, 2013 at 4:18 AM
