Is there an off on switch the light has always been off. One time it was on. I'm not sure if there is a way to turn it off and on.? If so how?
May 11, 2019 at 11:58 AM
DANNY L
✓Experienced Mechanic
Hello, I'm Danny.
Quick question first. Are you asking if you can manually turn the car clock light on/off ? Normally you can't as it controlled by the headlight switch when you turn the lights on at night. Hope this helps and thanks for using 2CarPros.
Danny-
