car can't star electrical problems
180,000 MILES
SINO456
  • 6 POSTS
I have a problem with my Nissan Micra 2004. When I turn on the car and it is cold the motor fan starts working and the blue light on the the dashboard is on. The overdrive light starts flashing, when running the vitesse hits when the gear chage fram 1st gear to 2nd and the rpm stops working. When turning the car off it won`t turn on again. I went to an electrical technician and he changed the fuse box placed behind the left headlight but the problem wasn`t solved.
I also changed the battery but the problem was not solved. I noticed that when the problem occurs the check engine light is not on after turning the key on contact. Please can someone help me, thanks ...
Best regards ...
May 20, 2013 at 4:23 PM
KHLOW2008
  • 41,812 POSTS
Symptom indicates a poor wire connection somewhere and such problems are not easy to detect. Start with checking wire harnesses for contaminations and ensure ground connections are good and secure.
May 21, 2013 at 12:14 AM
SINO456
  • 6 POSTS
thanks for your reply i will tell your hint to the technicien and tell u any news will happen. thak you again
best regards..
May 21, 2013 at 3:44 PM
KHLOW2008
  • 41,812 POSTS
You're welcome and good luck.
May 21, 2013 at 10:12 PM
SINO456
  • 6 POSTS
till now my problem was not solved :( :(
dear;
the electrical technicien tests all boards on another car and they worked properly
now he started releasing the body and all accessories to test wires connections but my question now is: Which wire or connection do like this problem and from where he must starts the test because there are a lot of wires ...
best regards and thanks for your time...
Jun 10, 2013 at 3:54 PM
SINO456
  • 6 POSTS
and also for hint i changed the pump from about 4 months.
is this problem because of changing the pump?
Jun 10, 2013 at 6:30 PM
KHLOW2008
  • 41,812 POSTS
It could be a fault with the pump or its wiring. Have those rechecked.
Jun 13, 2013 at 4:27 AM
