Starts then stalls, will not stay running
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
SPIRITHEART67
starts but stalls out wont stay running. doesn't seem to be getting fuel to engine. looks like fuel cutoff switch might be disconnected. have done some troubleshooting but I am stuck at this point. seems fuel line pump or switch related? help please!
Jul 20, 2019 at 10:48 AM
  • 110,251 POSTS
Welcome to 2CarPros.
It could be fuel related or other things. What I need you to do first is check for diagnostic trouble codes. This is an OBD 1 system and doesn't require a scanner to retrieve codes. Here is a link which shows how to get codes from this system. The only thing you need is the key.
____________________
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
See if you find any codes and let me know what they are.
___________________
Here is a link that explains how to check fuel pressure:
Here is the fuel pressure specifications:
1992 Plymouth Sundance Duster V6-181 2972cc 3.0L SOHC VIN 3 FI
Pressure, Vacuum and Temperature
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Specifications Pressure, Vacuum and Temperature
PRESSURE, VACUUM AND TEMPERATURE
Fuel Pressure* .................... 331 ± 14 kPa (48 ± 2 psi)
*Ignition key ON, engine OFF. Using DRB scan tool, access ASD Fuel System Test. The ASD Fuel System Test will activate the fuel pump and pressurize the system.
Jul 20, 2019 at 4:13 PM
