Car alarm malfunction
2007 TOYOTA CAMRY
70,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SEWELL26
The factory installed car alarm goes on without warning at different times of the day or night. Also the key fob (?) is capable of remote starting. The car is XLE.
Talked to a car alarm guy and he said that with cars of this age sometimes the door locks need lubrication because they don't shut or lock all the way with the sensor thinking someone is trying to break into the car and the alarm starts to ring.
Also, he said these cars have two pins under the hood that are pressed down when the hood closes and if they are not pressing down firmly the sensors think that someone is trying to open the open to steal the car and therefore alarm could start on its own. This might be the correct diagnosis because when I am driving, sometimes, a red triangle comes on at the dashboard where display comes on (mileage, temps and cruising range etc.) indicating "hood open" when the hood is not open and is locked.
I have tried to locate the pins pressed by the hood, but I can't locate them therefore any suggestion will be helpful (perhaps a diagram). THANKS.
Mar 5, 2016 at 2:31 AM
HMAC300
  • 48,601 POSTS
If you have tried resetting it then have a local professional see if something is wrong with module or switches. If no manual to reset then look online for your vehicle.
Mar 5, 2016 at 7:59 AM
SEWELL26
Thanks for your reply. I didn't know that the alarm could be re-set. If someone knows how to re-set it please send me the link or the information, otherwise I will look for it on the net and see what happens. Will let you know the result.
Mar 5, 2016 at 12:18 PM
CAR-MAN145
  • 321 POSTS
You should also check the battery connection, if its loose or dirty it could cause it to lose the connection and the alarm will go off when it reconnects.
Mar 5, 2016 at 4:44 PM
