Car alarm will not turn off, how do I turn it off?
210,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
SONIC PAINTER
I bought this used, had no idea it even had an alarm. I changed the serpentine belt/alt. belt and as soon as the new one was on, this alarm goes off nonstop. I can't even drive the car, it won't stop. How do I stop it?
Jan 27, 2024 at 11:58 PM
  • 110,251 POSTS
Replacing the belt has nothing to do with the alarm/anti-theft system, so this is a good one. LOL
The only thing I can think of is if somehow the hood switch was damaged when you were working under the hood. If possible, open the hood and locate the hood switch. It should be on the passenger side of the engine compartment. When you close the hood, the switch should make contact with the hood and complete the circuit.
Check to make sure the switch isn't damaged as well as the wiring to it.
Let me know what you find.
Jan 28, 2024 at 12:33 PM
