Car acts like it want to run hot with air cond. on.
217,340 MILES • MANUAL
CW4562
I recently had the heater hose replaced and I had fan replaced. However when I'm driving the car with the air conditioner on it looks like it wants to run hot right, but when I turn the air off, the temp needle goes back to normal. I don't have a problem as long as I don't turn the air on. The air blows when on and seems to cool. Could this be a thermostat or a fuse problem?
May 18, 2015 at 7:11 AM
CATAFINA
  • 167 POSTS
Check if the condenser fan is coming On
May 18, 2015 at 7:30 AM
HMAC300
  • 48,601 POSTS
besides checking condenser fan for operation which only should come on when a/c is on when hot check rad for cold spots with engine off if you feel any then the rad is bad
May 19, 2015 at 2:32 AM
