What is the correct pressure when charging AC
105 MILES • 2.7L • 4 CYL • AUTOMATIC
ISSYBIZ
My car's air is not cooling as good as it was before. I discovered it has been over charged by my mechanic. we have decreased the pressure from 60psi to 40psi, yet it is still not giving me the desired cooling.
Apr 2, 2018 at 6:20 AM
Good afternoon.
Pressure is not an indication of Freon level. you can have correct pressures but not enough Freon.
you will need to remove all Freon from the system, then add the exact amount called for on the tag under the hood.
The correct pressures are 25-30 lbs on the low side and the high side is two times outside temperature plus 15%.
This is with the compressor running.
Apr 2, 2018 at 7:34 AM
ISSYBIZ
I thinks it makes slot of sense. Am going to try it out and see how it is resolve the issue.
Many thanks for your responds..
Apr 2, 2018 at 4:08 PM
You are welcome. keep us updated.
Apr 2, 2018 at 8:52 PM
