Heater will not turn off and A/C will not turn on
22,200 MILES • 4.1L • 6 CYL • 2WD • AUTOMATIC
RON SPALDING
When running interior heater is on. Can’t turn off won’t turn down A/C won’t come on.
Aug 4, 2019 at 3:27 PM
  • 55,748 POSTS
This is common when the mode blend door actuator goes out. here is a guide to walk you through the repair with instructions on how the job is done one your car in the diagrams below:
You may have a vacuum leak under the hood that supplies the HVAC system as well. this guide will help:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Aug 6, 2019 at 4:28 AM
