Was driving about sixty miles car would not shift. came to a stop at red light and it died and now wont start.
Nov 19, 2016 at 12:56 AM
✓Experienced Mechanic
need to check all basics first, do you have fuel pressure, spark and injection pulse and i presume that it is cranking on the key?
Nov 19, 2016 at 4:30 PM
TINABOOTH
MEMBER
The number one spark plug is not firing and it's getting no fuel
Nov 21, 2016 at 11:32 PM
Hi Tina,
when you crank it over does it sounds the same as it did before it stalled? It could be the timing belt has broken. You can do a compression test or look inside the valve cover to see if the camshafts are turning while the engine is being cranked over.
