car died when stopped at light and now it will not start
191,000 MILES • 2.0L
TINABOOTH
Was driving about sixty miles car would not shift. came to a stop at red light and it died and now wont start.
Nov 19, 2016 at 12:56 AM
  • 31,937 POSTS
need to check all basics first, do you have fuel pressure, spark and injection pulse and i presume that it is cranking on the key?
Nov 19, 2016 at 4:30 PM
TINABOOTH
The number one spark plug is not firing and it's getting no fuel
Nov 21, 2016 at 11:32 PM
  • 55,721 POSTS
Hi Tina,
when you crank it over does it sounds the same as it did before it stalled? It could be the timing belt has broken. You can do a compression test or look inside the valve cover to see if the camshafts are turning while the engine is being cranked over.
Let us know what you find, Ken
Nov 22, 2016 at 3:03 AM
