How can I tell if the key fob battery needs replacement
4,446,509 MILES • 1.5L • 4 CYL • 4WD • AUTOMATIC
MELISSA JOHNSON
How to tell if you’re car key fob battery is dying and how to tell if the yellow oil is good or bad?
Oct 15, 2019 at 6:44 AM
The key fob key getting weaker is noticed by it not working as far away from the vehicle as it once did. Normally, these should work from about 150 feet away. If it is not then the battery is getting weak.
As for the oil, which oil are you talking about? Engine oil? If this is yellow in color or gold in color then it is probably okay. As it wears and gets dirty it gets darker in color until it turns dark brown and black.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Let me know if I am missing something or please clarify me if I got it wrong. Thanks
Oct 16, 2019 at 10:09 AM
