Cannot turn off or dim headlights when car is running
100,000 MILES • 6 CYL • AUTOMATIC
RUSS.KELLY
Hi Folks,
Just inherited the car listed above and I can't find any way to turn the headlights off when entering a military base where I work. The gate guards request I turn the headlights off but they don't seem to be controlled by the switch on the dash when the car is running.
Any ideas?
Russ
Apr 9, 2019 at 4:36 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I have some bad news. They can't be turned off in low light situations. The automatic headlamps and park lamps are designed to automatically illuminate when the ignition is RUN and the outside (ambient) light level is low, as in nighttime conditions. Light levels are detected by the ambient light sensor, a light sensitive transistor that varies its voltage signal to the Daytime Running Lamp (DRL) control module in response to changes to the ambient light level. When the DRL control module receives a low light signal from the ambient light sensor, it will then turn on the headlamps and park lamps and turn off the daytime running lamps.
When the ambient light sensor detects low light levels, the DRL control module turns OFF the daytime running lamps and turns on the headlamps and park lamps under the following conditions:
^ The ignition switch is in the RUN position.
^ The headlamp switch is OFF.
^ The park brake is OFF (released).
I wish I had a better answer, but that is how it's designed.
Apr 10, 2019 at 10:07 AM
