cannot turn engine over
2007 DODGE RAM
180,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PAUL BURKE
i have a blown engine. the crankshaft or connecting rods are broken and i cannot turn the engine over to extract the bolts from the flywheel to take out the engine what should i do? Any suggestions would be great. thank you.
Jul 12, 2016 at 9:14 AM
CJ MEDEVAC
  • 11,004 POSTS
Drop the pan.
Take the connecting rod caps off/ or take the nuts off of the connecting rod caps if the caps wont come off easily.
With a section of pipe, etc.
Beat the pistons upward in the cylinders (at least the ones that wont move) from the bottom side until they are free from the crank.
Maybe the crank will turn now.
The Medic
Jul 12, 2016 at 9:52 AM
  • 55,224 POSTS
Hey Paul,
I have run into this problem before, you can leave the torque converter bolts up and pull it out as a unit and then unbolt the converter once the engine is out.
Let us know how it goes
Best, Ken
Jul 13, 2016 at 5:46 AM
