can't start my car when the engine is hot
122,000 MILES • 1.8L • FWD • AUTOMATIC
TOYOTAC
WON'T START WHEN IT'S HOT
2008 Toyota Corolla
Electrical problem
2008 Toyota Corolla Two Wheel Drive Automatic ODO 122000
I have a 2008 Toyota Corolla; it always starts right up when it is cold, how ever, if I'm out & about running errands with several stops & starts, when it is hot, it will not start.
1) The fan is working correctly
2) The coolant level is good
3) Temperature gauge is at a good level
I usually have to wait 15-20 minutes and then if I'm lucky it will start right up.
If anybody has any ideas, I'd really appreciated.
Jul 24, 2014 at 10:54 PM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge may below and either filter is partially clogged or pump is going bad. autoparts rent it.
Jul 24, 2014 at 11:18 PM
