Cannot open trunk or gas door with key fob or dash buttons
97,890 MILES • 4.4L • V8 • 2WD • AUTOMATIC
PATMAN10466
I can't access my trunk or fuel door with my key fob or from dash board buttons. I checked fuses in trunk and valet button, no bad fuse in trunk Valet not on.
May 13, 2019 at 8:26 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with ground #404, which is located in the left rear of the trunk. Please check this ground and make sure there is no corrosion, clean, tight, and making a good metal to metal connection. This ground is responsible for completing both the trunk and fuel door circuits, as you can see in both of the system wiring diagrams that I have included in the diagrams down below. Please go through these wiring diagrams, check the ground and get back to us with what you find out.
Thanks,
Alex
2CarPros
May 13, 2019 at 2:10 PM
