Can't locate the crankshaft position sensor
160,000 MILES
EQEEZY
The car would be running fine for a little bit but after a while when the car comes to a halt the RPM goes really low and engine starts shaking and eventually stalls. I want to check the Crankshaft Position Sensor but I can't locate it. Any help would be appreciated. It is a Toyota Camry 1995 2.2L LE.
Apr 14, 2013 at 11:40 PM
SATURNTECH9
  • 30,868 POSTS
When it it stops running and won't start do you loose spark?
Apr 15, 2013 at 12:05 AM
