Power Window Circuit Breaker location needed
2007 SUBARU LEGACY
175,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
GREG BENSON
The windows on my 2007 Subaru Legacy won't roll down. They worked fine, then it was at the shop for a few months, now none of them work. I've checked:
1) The fuse. It was good, but I replaced it anyway. Still not working.
2) The relay. Good, replaced it anyway, still not working.
3) Wiring inside the door panel. Looks good. Removed and reattached the window wiring just for good measure. Nothing.
I've talked to my friend who is a certified mechanic and he is certain it is the Power Window Circuit Breaker. I've found the wiring diagram, but it's of no help to me. I've looked all over and can't see anything that resembles an auto circuit breaker. Even more incredible is that I can't seem to find any photo or video online of anyone else on planet earth doing anything with a 2007 Subaru Legacy power window circuit breaker.
I'd really like to get this fixed, seeing as the A/C is also broken. FML.
Apr 1, 2019 at 10:07 AM
JOETECHPRO
  • 705 POSTS
Hey GREG BENSON,
If you pull down the trim below the steering wheel the circuit breaker should live on/under that trim panel.
Should have a black/white wire and a white/green wire.
Hope that helps, sorry i don't have a location diagram that is of use.
Regards, Joe
Apr 1, 2019 at 10:32 AM
