smog failure for two years
45,000 MILES • 1.6L • V8 • 2WD • AUTOMATIC
PAULHARLEYMAN
Here is my story: I have this RV. It passed smog when I first bought it. Two years later I had to smog again and they found a low idle miss fire. My mechanic who has the AAA tag for excellence did everything and came up with the next and last solution of doing a 5,000 value job and said maybe that will fix it. $5,000 maybe. The cost was because it was a RV. Go figure. I took it to another place and it almost passed after tried to keep the idle up but the modules where not clearing and he said I need to drive it 400 miles and maybe that will help. I'm at a catch 22. I have been driving it illegally for three years now. I need a mechanic who know what to do. I live in Sacramento CA. Can you help me with someone or whatever. PS: The compression was also checked and it's at 150, and the mechanic did most everything you mentioned. There is always that but. I looked at your information but I'm not that good to follow it. maybe you can direct me.
Jan 19, 2019 at 8:52 PM
Good morning,
What were the results for the failure? I need the reading for the gases and any codes if they were set.
Jan 19, 2019 at 9:24 PM
PAULHARLEYMAN
I need a mechanic close to me. I cannot fix this by doing a question and answer online.
Jan 21, 2019 at 7:22 AM
I am trying to help you with the readings. I cannot fix it online but can give some ideas on what to do.
I am from central PA. I have no connections in your area.
Jan 21, 2019 at 7:36 AM
