Cannot get second rear caliper mounting bolt to align
102,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
BRYAN MCPHEE
Thanks for the great video. Regardless of what I do I cannot get the second rear caliper mounting bolt to line up (it is off just a smidge. I notice is on the new pads, the "tab" that is riveted to the piston side brake pad is on the opposite end of the pad. Also the squeal plate in addition to being riveted to the pad is bent over the top of the pad. Just thought of something, will try using both pads that do not have a tab in the same caliper.
Aug 10, 2017 at 12:07 AM
  • 110,251 POSTS
It sounds like you have the pads on the wrong side or you got the wrong brake pads. I would double check them to be sure here isa video so you can watch it again to figure out what's going on.
https://youtu.be/G5M_xKIxUb4
Mar 15, 2021 at 11:09 AM
BRYAN MCPHEE
Thank you the brake pads were wrong I got a set from amazon worked perfect!
