cant get no fire
250,000 MILES • 2.0L • V8 • 2WD • AUTOMATIC
LSUMAN420
Change out distributor and everything and and on top of it new wires and plugs not getting a spark
Feb 6, 2016 at 6:50 AM
HMAC300
  • 48,601 POSTS
check for power to dist first should be 12 volts if none check ignition switch. check to make sure carbon button is inside cap and will touch rotor. check pickup coil for 650-900 ohms no more no less.then have module tested at auto parts and imake sure dielectric grease is used under module in dist.
Feb 6, 2016 at 7:45 AM
LSUMAN420
Already replaced all that it stumped me
Feb 6, 2016 at 8:31 AM
HMAC300
  • 48,601 POSTS
re read my first reply see if you are getting power to it or not, then check coil for resistance.also check body to battery ground, eng/body ground and batt/eng grounds.
Feb 7, 2016 at 12:21 AM
