Cannot get it to start
136,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JERAMEY HEATH
i had the truck start 10 minutes prior then it ended up shutting off out on me i was unable to get a power connection. so i uncovered some of the clean wiring and reconnected the battery terminals. after clamping on the clean wiring the light on the dash comes on, but when i turn the key forward the light goes out and it seems as if i lost all power to the truck not even trying to crank over.
Dec 4, 2019 at 12:03 PM
  • 110,248 POSTS
If the battery is good and fully charged, you have a bad connection. Recheck the battery terminals making sure they are clean and tight. Also, confirm the ground from the battery to the engine block is in good condition, tight, and clean as well. Carefully confirm the wires on the starter are good.
Take a look through this link. It may be helpful.
Please keep in mind, if the battery is nearly dead, the same thing can happen, so reconfirm that it is charged and in good condition. If you can, remove it and take it to a parts store. Most will load test it for free.
Here is a way of testing the battery at home, but you need to get it back to the point where the lights work:
Dec 4, 2019 at 12:57 PM
