Hesitates on take off and backfires
269,843 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RALPH CHAVARRIA
New distributor, rotor, wires,cap,plugs,idle air control valve, map sensor, TPS, oxygen sensor,knock sensor, timing set on point. starts but when i give it gas hesitates on take off and backfires. Help.
Jun 17, 2019 at 2:08 PM
Good morning,
I would start by checking the compression. It will tell us if the engine is internally food and if the valve timing is correct.
Did you verify the firing order?
https://www.2carpros.com/articles/engine-backfires-while-running
Jun 17, 2019 at 7:43 PM
RALPH CHAVARRIA
Yes, i did timing checked it five times.
Jun 18, 2019 at 5:01 PM
RALPH CHAVARRIA
I need to get a pressure testing device to check it.
Jun 18, 2019 at 5:02 PM
Okay, keep us updated.
Jun 18, 2019 at 7:42 PM
RALPH CHAVARRIA
Thank you Roy.
Jun 19, 2019 at 7:26 PM
You are welcome.
always glad to help.
Jun 19, 2019 at 8:42 PM
