Cant get fuel in tank
120,000 MILES • 3.6L • 6 CYL • AWD • AUTOMATIC
KERRY BUTLER
When I put petrol hose/nozzle in and pump petrol it spits it back out like it is blocked or something? Petrol tank is empty.
Apr 22, 2016 at 8:29 PM
  • 31,937 POSTS
The fuel tank breather is blocked, run a scan and check for a faulty purge valve.
Apr 22, 2016 at 10:06 PM
  • 55,746 POSTS
Hi Kerry Butler,
The tank has a check valve in the filler neck it sounds like your is stuck, you will need to remove the filler neck and see what happened. Please let us know what you found.
Best, Ken
Apr 22, 2016 at 11:57 PM
