Can't get driver side window up...
100,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MATHEWSCHMIDT
So my driver front window is stuck mid way. Can't get it up. I can hear the motor running. I opened door trim and try to manually push up the plastic clamp that holds the glass, but doesn't budge. I figure the regulator is bad. I hardly use the car so don't want to replace the part. All I want to do is get the window up and keep it that way. I will keep it closed forever. it is 98 mercury mystique. Appreciate the help. Thanks.
Aug 26, 2016 at 5:49 AM
WRENCHTECH
  • 20,758 POSTS
Yes, you have a bad regulator. At this point the wire cable is likely tangled and wrapped around something preventing the window from moving. You could spend the time and effort to go inside the door and untangle this mess but at that point, you are only $60 to $70 from having a new regulator. You might as well change it.
Aug 26, 2016 at 5:54 AM
MATHEWSCHMIDT
i have the door trim opened and can see the glass and regulator. How to untangle the cables.
Aug 26, 2016 at 9:12 PM
WRENCHTECH
  • 20,758 POSTS
I can't see how they are jammed from here or if it can even be un-jammed. Just replace the regulator and be done with it.
Aug 26, 2016 at 9:27 PM
