Cant fill my tank without having issues
DANIIBOII24
when filling up, the pump shuts off after about a quarter of a gallon. and most of the time some of the gas shoots out of the filler tube by the nozzle
Jan 15, 2015 at 9:33 PM
HMAC300
  • 48,601 POSTS
check to see if the vent hose is blocked or kinked it's the small hose by filler tube hose
Jan 15, 2015 at 10:32 PM
DANIIBOII24
What am I looking for? I notice that the return line thing, at the top of the bend on the filler neck, on the inside of the filler neck the piece has an aluminum looking cap that looks like its blocking the flow of gasoline
Jan 16, 2015 at 3:06 AM
DANIIBOII24
there are no kinks or major bends. it is clipped to the filler neck. i have blown air through it. not compressed air, but by mouth
Jan 16, 2015 at 3:07 AM
HMAC300
  • 48,601 POSTS
that is kind of a anti roll over device so the tank won't leak fuel when car rolls. if there are no kinks of hard bends then try blowing through it to see if it 's clear other than that I have no idea what to tell you on this. you cold try moving air through the vent not the filler and see what you have.
Jan 16, 2015 at 4:16 AM
