Cannot select gears when the van's engine is running
89,000 MILES • 1.9L • 2WD • MANUAL
DH399132
When the van has started and running you cannot select any gears. When the ignition is off you can select a gear okay, depress the clutch and start the van, it will then go okay but will not be able to select a gear. You need to switch off to select a gear? Has been fine since this.
Oct 5, 2018 at 8:06 PM
  • 55,673 POSTS
The clutch has gone out, the disc is not being released. Here is a guide and a video to show you how to fix the problem the car is not the same but the process is very similar:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
and
https://youtu.be/6N6b5F2ChyE
Cheers, Ken
Oct 7, 2018 at 5:55 AM
