Cannot resolve code P0420
184,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
HVDES
Hi, I have been battling this P0420 code on my car (GT model) for a while now and was hoping someone would have some more insight on the subject.
- I have replaced both oxygen sensors as well as the catalytic converter.
- Replaced the PCV valve.
- I have put in new plugs and wires.
- I have cleaned the MAF sensor and air filter.
When driving, the car has a hard time accelerating. Especially up-hills and when accelerating to highway speeds, there is a ticking noise that sounds similar to a card in the spokes of a bicycle but is not heard when idling. Also, when I start the car it fires up right away then will cut immediately off if I do not tap the gas pedal.
Could it be a bad MAF sensor? I tried to test it with a multimeter but it is nearly impossible with the harness that it has.
Anyway, thanks.
Jul 26, 2018 at 12:29 PM
Good morning.
What brand catalytic converter did you use for the replacement?
The noise could be a valve tap from a valve issue with the motor. You need to have that checked as it may be causing a misfire and that will overheat the catalytic converter and cause the code as well.
P0420
Descriptor
Engine Controls
Probable Causes
Catalytic Converter
Catalytic Converter Bank 1 Blocked
Catalytic Converter Bank 1 Damaged
Diagnose Other DTCs First
Engine Misfire Detected
Engine Oil or Coolant Consumption Excessive
Exhaust Leak
Exhaust System Damaged
Exhaust System Hardware Loose or Missing
Fuel Mixture Lean
Fuel Mixture Rich
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Damaged
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Loose
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Pigtail or Wiring Harness Contacting Exhaust or Ground
Oxygen Sensor (O2S) or Wiring Harness Damaged
Three Way Catalytic Converter (TWC) Does Not Meet Manufacturer Specifications
Weak or Poor Spark
Jul 26, 2018 at 10:45 PM
HVDES
I do not think it is valve tap as I only hear it when I am above about 2,500-3,000 rpm's and it is not very loud but, the converter I put on is from eBay and I think it is this exact one.
https://www.ebay.com/itm/2004-2005-2006-Pontiac-Grand-Prix-3-8L-Direct-Fit-Catalytic-Converter-/253764966466?hash=item3b15921842
Jul 27, 2018 at 8:14 AM
Okay.
It looks like this one does not have enough precious metals to keep the light out. That is the issues with the cheap converters.
Walker and Bosal are the only ones we use due to come backs from the 420 returning.
Jul 27, 2018 at 8:18 AM
HVDES
But the lack of quality of the converter should not be causing the car to accelerate slow and strangely would it? The car also seems to show all the symptoms listed here for a bad MAF sensor.
https://www.carsdirect.com/car-repair/how-to-tell-if-you-have-a-faulty-mass-airflow-sensor?src=20&lnk=eyzsD2QGsYg-jBWJdbuvzn%2Fj4mDqmhlHtw
Yesterday I unplugged the senor and drove it down the street to see if there was a difference in how it accelerates and it seemed to be running the same.
Thanks
Jul 27, 2018 at 8:27 AM
Okay, the original question was your 420 code. We through that the sluggish.
I would start by doing a fuel pressure test to be sure you have enough fuel for the injectors to work correctly.
also, I would do a compression test to see if there is a issue with the timing chain.
Jul 27, 2018 at 9:33 AM
HVDES
I have tested the car with a scanner and it says all sensors and systems passed except the EVAP system, but I do not have any codes related to it. Do you think a bad solenoid or vapor canister could be causing these problems?
Thanks again.
Jul 28, 2018 at 4:05 PM
They are only monitors. That does not mean there is no problems with those systems.
You need to do the two tests I suggested in my previous answer.
Jul 28, 2018 at 10:51 PM
GJGOGOL
ASEMASTER6371, how does one know if a cat has enough precious metals?
Aug 21, 2023 at 7:34 AM
  • 55,845 POSTS
I believe all catalytic converters have precious metals, here is more information:
Catalytic converters are devices used in the exhaust systems of vehicles to reduce harmful emissions by catalyzing various chemical reactions.
Platinum (Pt):
Palladium (Pd):
Rhodium (Rh):
These precious metals are often supported on a ceramic or metal substrate
Aug 22, 2023 at 3:42 AM
GJGOGOL
KEN L - Thank you for your reply. ASEMASTER6371 mentioned that the cat may not have enough precious metals to keep the light out. I am looking for a new cat and I don't see anywhere where the seller states "how much" precious metals are used. I am "assuming" that if it is either EPA or CARB compliant, they have sufficient metals in them. I could be wrong, thus my question.
Aug 22, 2023 at 4:28 AM
