Truck ran okay, went out next morning will not start.
Sep 20, 2020 at 3:52 AM
✓Experienced Mechanic
The fuel pump relay is part of the IPDM. I attached the info on this. Does the fuel pump turn on when you turn the key? If it does, we need to check pressure as the relay is working.
