Cannot go into gears
80,000 MILES • 1.3L • MANUAL
CARGIRLJEN
When I put my foot on the clutch and attempt to put the gear stick in any gear, it moves out of position and looks like it springs back to neutral.
Jun 29, 2020 at 5:43 PM
Good morning,
I attached a recall for you to view on this issue.
I would call the dealer and give them your VIN number and see if your car is involved in the recall.
If the plate fractures, it could bounce the shifter back to neutral.
Beyond that, it sounds like you will need a clutch.
https://www.2carpros.com/articles/how-to-replace-a-clutch
Report Receipt Date: MAY 16, 2016
NHTSA Campaign Number: 16V302000
Component(s): POWER TRAIN
Potential Number of Units Affected: 39,217
RECALL Subject: Clutch Diaphragm Spring May Fracture
Manufacturer: Chrysler (FCA US LLC)
SUMMARY:
Chrysler (FCA US LLC) is recalling certain model year 2012-2016 Fiat 500 vehicles manufactured June 21, 2010, through January 12, 2016, equipped with a manual transmission. The clutch diaphragm spring may fracture and fail, causing an inability to switch gears.
CONSEQUENCE:
If the clutch diaphragm spring fails, the driver may not be able to shift gears or the vehicle may lose motive power, increasing the risk of a crash.
REMEDY:
The remedy for this recall will include the installation of a clutch pedal limiter and a clutch pedal switch. Interim notices will be mailed to owners in June 2016. Owners will receive a second notice when remedy parts become available. Owners may contact Chrysler customer service at 1-800-853-1403. Chrysler's number for this recall is S34.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
REMOVAL
1. Remove battery tray See: Battery Tray > Removal and Replacement > Battery Tray - Removal.
2. Remove air cleaner assembly See: Air Filter Element > Removal and Replacement > Air Cleaner - Removal.
3. Remove the ground strap (1) from the transmission.
4. Disconnect reverse lamp switch connector (1).
5. Remove the slave cylinder bolts (1) and secure the cylinder out of the way.
6. Disconnect shift selector cable (1) from the lever.
7. Disconnect the cable from the mounting bracket (1).
8. Disconnect the shift cable (1) from lever.
9. Disconnect the cable from the bracket (1).
10. Remove upper bell housing bolts (1).
11. Remove the upper starter bolts
12. Raise vehicle on hoist.
13. Remove the belly pan if equipped See: Underbody Cover > Removal and Replacement > Belly Pan - Removal.
14. Remove the cross car cradle brace (1).
15. Drain the transaxle fluid See: Fluid - M/T > Procedures
16. Remove both halfshaftsSee: Axle Shaft Assembly > Removal and Replacement > Half Shaft - Removal.
17. Remove the Front Fascia See: Front Bumper Cover / Fascia > Removal and Replacement Front Bumper Fascia - Removal.
18. Remove two bolts (1) and the left vertical brace from the vehicle.
19. Remove four bolts (2) and the left lower frame extension (1).
20. Disconnect the oxygen sensor wire from the loom/clip (1).
21. Carefully support the engine with a screw jack or the equivalent.
22. Install a suitable transmission jack to the transmission.
23. Remove the left side bolts (1) and mount.
24. Remove the rear transmission mount bolt (1) from the frame.
25. Remove the rear transmission mount bracket bolt (1) and bracket from transmission.
26. Remove the remaining transmission bell housing bolts (3).
27. Remove the nut (1) and the stud (2) from the transmission case to facilitate removal.
28. Remove transaxle from vehicle.
Jun 29, 2020 at 9:40 PM
