Candy bar in tank
180,000 MILES • V8 • 4WD • AUTOMATIC
ALISSIA TIERRA DUKES
This morning i woke up started my car it ran for about ten minutes and then cut off and tried to start it again but it will not start. what should i do?
May 16, 2017 at 4:48 AM
HMAC300
  • 48,601 POSTS
a candy bar will not do much so do not worry about it. the only thing it may do if it even gets past the anti rollover valve in tank is block filter in tank and only partially. if check engine light is on scan for codes and check fuel pressure with a gauge auto parts rent the gauge. See link.
May 16, 2017 at 5:18 AM
