cannot set idleing
140,000 MILES • 1.5L • 4 CYL • FWD • AUTOMATIC
EBRIM
when put the car in gear or turn the air conditioner on the idle goes up and down until the car quits. When I put the transmission in natural it goes up and down, but stays running as long as air conditioner is off. I replaced the throttle body twice and the o2 sensor.
May 5, 2016 at 7:28 AM
HMAC300
  • 48,601 POSTS
scan for codes and check for a vacuum leak, clean throttle plate on both sides and iac hole with choke cleaner. also check for air leaks between air cleaner and throttle body
May 5, 2016 at 8:46 AM
RENEE L
  • 1,260 POSTS
Here is a link to an article that features written instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one from Amazon.com. Once you have the codes please get back to us so that we can further assist you. Thank you for visiting 2CarPros.
https://youtu.be/YV3TRZwer8k
May 5, 2016 at 9:20 AM
