Replace rear brake shoes and wheel cylinders. At that time replace front calipers. Bled the system. When car is not started has a firm brake pedal but when you start the car the pedal goes almost all the way to the floor.Waited a couple of hours and re-bled the brakes. Found more air bubbles. Once all the air bubbles were removed. Had a firm brake pedal without the car being started. Started the car and the brake pedal did the same thing went almost all the way to the floor. Any suggestions on how to get this problem to go away?
Aug 11, 2016 at 6:44 AM
