codes; 12, 53 AND 54
204,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
ERIK IBARRA
Hello everyone, I have been having trouble when I try to start my car, when the weather is hot and the car is in the sun does not start, when it starts and I am driving on the road the alarm light comes on and stays on, after this needle speed and revolutions are stuck or down to 0. when this happens my car starts to shake, I have to leave the road and turn off the car, but then will not start. I hope you can help me. I am using translator I cannot write good English, but if I get to read.
Oct 31, 2016 at 3:29 AM
HMAC300
  • 48,601 POSTS
there is no code 12 there is 11 and 13 which mean no cam signal. there is no code 53, but there is code 54 which means no crank signal try locking and unlocking drivers door as this may reset security system otherwise you need a scanner to see what is wrong with it as it could be a body module problem. also check your ASD relay under hood see link to security systems butnot sure it will relate to your car.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Oct 31, 2016 at 5:10 AM
